Nobody ? Not even a virgin DUMP ??? thanks
Hello ,
I need some help with this fault code from this unit
Unit no : 30773786
Fault code : 012C - Can configuration Faulty
After i erase the fault with diagnostic, SRS light stays on but as soon as i stop the car and start it again the fault code appears again...
MCU is 1L59W
I attach eeprom here. Maybe anyoane can guide me where the fault is or maybe a virgin file for this unit and after that reprograming on the car with VIDA ???
I found a link on google with same problem but google translate fails to make a good translation...maybe somebody can help me with polish language and maybe can make me understand aswell.
Any help is much appreciated. thanks
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
Hi, test this file , pass pm.
bursuc (17th March, 2017)
Somebody maybe has a solution for this .... it must be a virgin file somewhere around ... i desperately need a solution to virginise this unit ----
No, it's not virgin, sorry I've not got a virgin file for this unit.
you need right flash not eeprom. what model what year LHD RHD?
RHD - so , to make it virgin you only need right flash ? mmm ...is something that i,m missing here ? when i exchange a unit i just copy the eeprom data in order to make it to work on that car...so it must be something inside eeprom data
Its a bit more coplicated...
pm me your vin or if car is uk registered reg number.
will try to find rightone for u.
bursuc (27th April, 2017)
i am having a similar issue and need the correct software to flash, does it contain the vin number and if so can the vin number be edited to match the car without access to the original module?
Hope someone can help me,
I have the same issue,
I have an error code of 012c showing incorrect software for the car, I don't have the original module co copy data from, can anyone modify the software I have or supply me with the correct software from vin number or reg number?
