Results 1 to 9 of 9
    Default Ducato 2.8 problem engine start
    Have a Ducato 2.8 with edc 15c7,that engine only work at second crank.
    To make it work need to ,ignition on ,starter,ignition off/on ,starter and engine run.
    Immo light off.
    Ecu fault code p1320,syncronization rpm/camm,confirmed the signals and syncro. correct
    If some on could help me.
    Meat-Head's Avatar
    Might be worth pulling both sensors out check no metal filings, sensors can go weak
    price up genuine sensors and aftermarket, sometimes worth just swapping to elimnate if cheap enough
    if ?45566 each then yes check carefully
    remember tge thankssssss button
  3. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    doctore (17th March, 2017), synkrotronic (17th March, 2017)
    I checked with scope and do not see any damage on signals.
    With the two,seems to be correct the timing too.
    Meat-Head's Avatar
    Can you swap cam and crank sensors around?
    nissan primera P0340 can swap works for a bit.
    are you scoping at ecu or sensor?
    for reference had a customer we dont like, his the same, crank crank nothing, cycle ignition starts
    he had it remapped to go faster afterwards was still crank crank crank
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
  7. #5
    Scope on sensors
  8. #6
    Meat-Head's Avatar
    Quote Originally Posted by synkrotronic View Post
    Scope on sensors
    Ok, repeat experiment, scope at ecu, incase voltdrop
    if you hot 4 channell match each end
  9. #7
    Thanks will swap too sensors ,will report
    Regards
  10. #8
    Solved,changed cam sensor position (1 mm !!?)
    Thanks for your attention
  11. #9
    Meat-Head's Avatar
    OFF TOPIC:-
    now you said that YEARS ago had opel astra, cant rember feult but 100% ecu and
    crank sensor, new sensor from dealer still no start, so in desperation SWUNG on the tiny
    M6 bolt with 2meter scaffold pole and cured it, just this was a nats bollock to far
