Hi all, Im happy to report that it worked! Followed the soldering instructions from the KESS photo i posted.
Big up and thanks to Pulsar2000, OVERSPEED, for the time they took to guide me along! Good stuff!
Hi Pulsar2000, thank you for your kind words.. had the same idea as you to cannibalize the parts/wire from the kess v2.
So now, im not sure which diagram to follow, regarding the soldering of the resistors. My diagram from kessv2 or the one you posted, also not forgetting OVERSPEED also mentioned something about 680ohm resistors instead of 100ohm stated im both our diagrams
slickkon (20th March, 2017)
Ok latest update. Was driving around normal these few days. Today, something weird happened. Drove as normal, parked and went around my business. Came back, damn car doesnt start?! Got same symptoms as the bricked ecu. Removed my battery.. and reconnected.. still nothing.
Removed battery and unplugged ECU harness. And it starts? But only ONCE. Now everytime i turn the engine off, i gotta unplug the ECU and plug it back again.
Seriously.. it never ends..
Anyone got any ideas? Appreciate the help..
might be worth checking all connects and solder joints , you could also change the 12v to ignition 12v feed as its your car
Sorry dont quite understand how to go about it..
What do you reckon in going on here? Bad programming? But the car starts everytime i physically disconnect and connect the ECU.
How do i go about change the ignition? Its weird.. after the first time i try to start the car.the secomd time i put it in 'acc' The fuel pump doesnt come on, all sorts of asr errors, hill holder error, abs error.. cant be immobiliser as the fuel pump will come on even with immo on, just wont turn over.
Unplug ecu, plug it back.. starts like nothing happened..
Did you reseal ECU Lid properly ?
Any chance PCB getting rain in or wet ?
Just a thought
Hu Pulsar2000.. yes.. lid closed tight.. no apparant moisture whatsoever.. anyone else can chime in to help? Never encountered this before.. usually it either works or it doesnt..
and was ok before you map ecu ?
must be some damage when solder, or check carefully all solder off where you put resistor
Yeah, was fine until today.. thanks for advice.. will check solder points again..
If it start only one time it?s is a CKS error, I get one of this using ECM on these ECU.
slickkon (22nd March, 2017)
Hi OVERSPEED, thank you for your reply. How do I go about correcting it? Reflash it again? But ECM checksum is same for all the Fiat Me7.9.10 right?
And youre right, i did use ECM to checksum it the first time around.. its weird it suddenlu acting up..
which other method or program to do the checksum again? Thank you OVERSPEED
If you use MPPS it will not change CKS, if you write by OBD with Kess it does the CKS when writing and work... only ECM has one or more CKS adress less then it shall be
pulsar2000 (22nd March, 2017)
Hi all, once again, i feel like i cheated death with your help. Thank you guys. Respect.
