Results 1 to 7 of 7
    Member xlinuxasx's Avatar
    Jul 2012
    Default Renault Scenic 2004 starting problem
    Hello.
    Cannot start Renault Scenic 2004 1.9dci 88kw.
    When I push start button, starter not spinning. Replaced starter but nothing. When I tow the car, it can be started. Also on display I see Check injection.
    I connected Delphi ds150, and got code 1486 unknown. Sometimes second code shows - DF025.
    Any help please!
    Jul 2012
    In live parameters I see Rail pressure 5bar, and Rail pressure setting 268bar. Is it normal?
    Jul 2013
    yorkshire
    5 bar is not enogh
    Starting see if value goes to around the 200 bar
    rideon's Avatar
    RO
    Quote Originally Posted by autoden View Post
    5 bar is not enogh
    It is with ign on and
    Quote Originally Posted by xlinuxasx View Post
    Quote Originally Posted by synkrotronic View Post
    As soon as the starter will start spinning ...
    @xlinuxasx
    check 20 some fuse in under bonnet fusebox while at it keep an eye open for water ingress..
    A failure will not appear till a unit has passed final inspection
    May 2016
    manosque
    SLT v?rifie les fusible compartiment moteur sous la plaquette ?lectronique
    BAILE ATHA CLIATH
    Almost Definitly 30 A fuse in fusebox under bonnet hard to get at at back of box
