Page 2 of 10 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 144
  1. #16
    auto techniek's Avatar
    Mar 2017
    I ve ordered one and trying to order transponder chip.
    Do I ve to order special chips made bij JMD or can I use the universal one.
    The one made by JMD are more expensive. Is there any quality issues?
  2. #17
    And what about 48? Works on anything?
  3. #18
    scotland clydebank
    this device is superb normal 48 is good also does latest vw with cs but you need to buy jmd assistant for that for toyota g chip extra and latest ford cloning g feature need enabled extra transponder chips make sure the work with
    latest software transponder are half the price of silca or keyline and does also lost keys the best portable device the Ariel pick up is excellent just look at you tube several video from developer showing how to use device
    on your tube excellent kit .
  4. The Following User Says Thank You to godfathertre For This Useful Post:
    auto techniek (1st July, 2017)
  5. #19
    Mar 2017
    What I understand is no need to buy JMD chips.
    Normal id48 are good. What about others transponders?
  6. #20
    Which transponders does it use to copy 48? Those black inside or special ones?
  7. #21
    scotland clydebank
    do not know about id 48 i have the transponder ordered just look at the video in you tube the developer goes trough all different transponder types .
  8. #22
    scotland clydebank
    no you need handy baby transponders does not work with normal 48 transponder or vw can just tried on my handybaby just google handybaby all function you tube.
  9. #23
    I understand that normal transponders doesn't work. But there are 48 transponders in which you can edit ID (normal glass, but black inside) and they are faulty, stop working after some time. I hope that they use their own transponders.
  10. #24
    Mar 2009
    Quote Originally Posted by EMCE159 View Post
    yeah u have to buy jmd id48 to work
    I tried normal 1s and never worked but the jmd48 work fine
    done my own mk5 golf fine with jmd assistant
    as you cannot just copy ur golf key u have to use assistant
    unless some 1 knows different
    also done a few fords and work fine with jmd4d
  11. #25
    drugowaz's Avatar
    Mar 2015
    Lithuania
    jdm.assistand is only for VAG id48?
  12. #26
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by rdu04 View Post
    the problem was solved helping whiskeyman
    thanks again
    So did you do with the software DAER posted here?
    Because this software he posted here is just for version start in 6.0.0.
    5.2.0 need the old software.
    No?
  13. #27
    Just seen a video on cloning an Ford id63 carbon chip anyone tried it ?
  14. #28
    Mar 2017
    I see there is only four chips available for this device. id46,id48. 4c4d and G chips
  15. #29
    drugowaz's Avatar
    Mar 2015
    Lithuania
    ford has 4D
  16. #30
    Mar 2017
    How to recognize difference between the F-JMD 8 from C-JMD 8? or is F-jmd 8 out of production?
