Page 3 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 144
  1. #31
    drugowaz's Avatar
    Mar 2015
    Lithuania
    is this true?
    https://youtu.be/dKOR9JSZtHw
    it can copy 4d 80bit keys for new fords?
  2. #32
    Jul 2015
    Quote Originally Posted by drugowaz View Post
    is this true?
    Some of them.
  3. The Following User Says Thank You to gokart For This Useful Post:
    drugowaz (7th July, 2017)
  4. #33
    drugowaz's Avatar
    Mar 2015
    Lithuania
    can anyone tell me about id48 jmd48 chips.
    i see ones is in plastic capsule ,others in glass.
    which ones are working?
    [5PCS/LOT] JMD48 Chip For Handy Baby ID48 JMD 48 Copy Transponder Chip Rewritable Chip For CBAY Hand-held Auto Key Programmer
    http://s.aliexpress.com/FbIjqqmY
    (from AliExpress Android)
    ive rad that ones in plastic capsule not original and dont work
  5. #34
    drugowaz's Avatar
    Mar 2015
    Lithuania
    anyone know?
  6. #35
    auto techniek's Avatar
    Mar 2017
    where do you see it is a plastic capsule?
    I think it is glas
  7. #36
    drugowaz's Avatar
    Mar 2015
    Lithuania
    this not looks like glass
    https://www.aliexpress.com/item/5PCS...ddresstype=600
    ANYOEN TESTED THESE?
  8. #37
    Jun 2014
    I got ten green ones and none worked. But I heard that other peoples worked so maybe I got a bad batch/.
  9. #38
    May 2013
    This Handybaby copies FORD 4D63 80 Bit. You must use the PC software for cloning these chips. It requires blank JMD-G chip to write the Ford 4D63 80 Bit. Haven't coem across another machine that clones these newer ford chips.
    Remember only buy Genuine JMD chips or else you will be throwing your money away. The new firmware has a method of checking if the chips are original JMD or not and will not copy to fake JMD chips.
  10. #39
    drugowaz's Avatar
    Mar 2015
    Lithuania
    cloning 80but fords need G licence active?
  11. #40
    Mar 2017
    JMD handy baby comes uit with a King chip. One chip can copy 4c,4d,46,48 and G chips.
    https://www.youtube.com/watch?v=MXmx...ature=youtu.be
  12. #41
    Jun 2014
    yes needs activation. does Toyota G Chip too.
  13. #42
    Jul 2015
    Quote Originally Posted by dustin2014 View Post
    Nope. Toyota G is needed only for Toyota G.
  14. #43
    drugowaz's Avatar
    Mar 2015
    Lithuania
    so ford 80 bit cloning online without G licence?
  15. #44
    Jul 2015
    Correct.
    //again not enough words
  16. #45
    super jumbe's Avatar
    Livingstone
    Lads can this Handybaby copy all VW 4th generation ID48 Chips with JMD Assistant tool?
    Need to know tested solution only.
