Try & report
Try & report
Thanks. Unfortunately it doesn't work.
Result: Airbag light flashes. Unable to connect to airbag unit using factory diagnosis tool.
After reprogramming to original content, the unit starts and behaves as previously (crash record).
Original dump:
FF FF FF FF FF FF FF FF 80 FF FF FF 34 BC B3 80
64 9B 23 74 16 4C 1D 50 1F 30 30 0C 04 4E FF FF
FF FF FF FF FF C1 C1 B0 B0 B5 B0 37 38 34 38 FF
FF FF FF AA FF FF 14 01 00 9E 00 62 03 92 FF 0C
FF FF FF FF FF FF FF FF 7F FF FF FF CB 43 4C 7F
9B 64 DC 8B E9 B3 E2 AF E0 CF CF F3 FB B1 FF FF
FF FF FF FF FF 3E 3E 4F 4F 4A 4F C8 C7 CB C7 FF
FF FF FF 55 FF FF 03 00 00 9E F0 40 03 13 FF 0C
The memory seems to be hashed. Compared to other 5WK40xx (i.e. BMW e36 5WK4060) the addres bit 0 and 5 are chenged.
The dump after decoding should be like:
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 7F FF FF FF FF FF FF 34 CB BC 43 B3 4C 80 7F
64 9B 9B 64 23 DC 74 8B 16 E9 4C B3 1D E2 50 AF
1F E0 30 CF 30 CF 0C F3 04 FB 4E B1 FF FF FF FF
FF FF FF FF FF FF FF FF FF FF C1 3E C1 3E B0 4F
B0 4F B5 4A B0 4F 37 C8 38 C7 34 CB 38 C7 FF FF
FF FF FF FF FF FF AA 55 FF FF FF FF 14 03 01 00
00 00 9E 9E 00 F0 62 40 03 03 92 13 FF FF 0C 0C
The crash record is highlighted in RED.
However, still not sure how to clear it. Putting 00s or FFs causes removal of crash record (ecu responds) but there is an error "Control unit faulty" (probably bad eeprom checksum or invalid fill bytes in crash record).
HELP !!!!
Reorganized original file with crash data
Solved. Clean data below.
FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00
80 7F FF FF FF FF FF FF FF FF FF FF FF FF FF FF
