Results 1 to 15 of 25
    rola1971's Avatar
    Jun 2014
    Dublin
    Default VOLVO key programming
    i need good key programmer for VOLVO cars
    for
    S40 v40 from 2005
    s60 from 2010
    and for s80 from 2008
    what devise or programmer you used
    Thanks for help
    p1et's Avatar
    Oct 2013
    rola1971's Avatar
    Jun 2014
    Dublin
    i know abritus but may be andavan devise.
    x300 or x100
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    nothing exists for newer Volvo expect Abrites (and that has huge limitations) and main dealer kit
    - expect you've been asked to do Volvo cos others can't. Only the old crap is covered - i do em by eeprom
    I am a FUD
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by obdsystems View Post
    yes from eeprom i know but you programming only for start no chanse programming remonte
    i check anadavan devise
    https://www.youtube.com/watch?v=litcCgbRUs4
    rob h's Avatar
    May 2011
    http://www.lonsdor.com/html/case/13
    Using chrome and translate, i can gather that it reads data with a programmer first.
    Then you sent the data to the support team. They will convert it for you.
    The device is called Lonsdor K518.
    http://www.digital-kaos.co.uk/forums...0-LONSDOR-K518
  7. The Following User Says Thank You to rob h For This Useful Post:
    habbyb (22nd May, 2017)
    Nov 2017
    Quote Originally Posted by rob h View Post
    Here is the English Version:http://www.lonsdork518.com/service/l...60-key-11.html
    Lonsdor k518 support Volvo car list:
    Series Origin Year Fuel Type Function
    S60 Other Other Other Proximity Key[insert key to start]
    S60 Other Other Other Smart Key[one-button start]
    S80 Other 09- Other Smart Key[one-button start]
    XC60 Other 09- Other Smart Key[one-button start]
    S80 Other 09- Other Proximity Key[insert key to start]
    XC60 Other 09- Other Proximity Key[insert key to start]
    S40 Other Other Other Smart Key
    S40 Other Other Other Key Programming
    S80 Other -09 Other Proximity Key[insert key to start]
    V40 Other Other Other Proximity Key[insert key to start]
    C30 Other Other Other Key Programming
    C30 Other Other Other Smart Key
    V40 Other Other Other Smart Key[one-button start]
    S80 Other -09 Other Smart Key[one-button start]
    V60 Other Other Other Proximity Key[insert key to start]
    V60 Other Other Other Smart Key[one-button start]
    XC60 Other -09 Other Proximity Key[insert key to start]
    XC60 Other -09 Other Smart Key[one-button start]
    XC90 Other Other Other Flip Key
    C70 Other Other Other key Programming
    C70 Other Other Other Smart Key
    V70 Other 09- Other Proximity Key[insert key to start]
    V70 Other 09- Other Smart Key[one-button start]
    Jun 2013
    Quote Originally Posted by sterver View Post
    Need to mention that data needs to be read out on the bench with programmer which is included.
    So it is not straight away with OBD, and all done in minutes.
    AVDI does this only by OBD. But can use up to 4 hours of calculation.
    But what I really would like to hear about, is how the Datasmart does this. They got this added as well this year.
    Is it only by OBD? Or need to read out the info on the bench with a programmer.
    Remote is OK?
    Anyone tested this solution. Difficult to find any info on this one.
  10. The Following User Says Thank You to Weasel3 For This Useful Post:
    rob h (23rd November, 2017)
  11. #9
    Dec 2010
    Nottingham
    i understand that smart pro the new machine from advanced diagnostics due for release next year has volvo programming by obd and im told quickly too , diagnostic box has also started to add this but i think only 1 model on this one at mo.
  12. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    p1et (23rd November, 2017)
  13. #10
    narkeleptk's Avatar
    May 2017
    USA
    I used to eep all Volvo's but got sick of pulling L cems and repairing missing pads on older cems so started just using VIDA with a cardaq instead. Pricey for each program but it works like a dream for both transponder and keyless entry. Worth the time and headache saved for sure.
  14. #11
    Aug 2015
    Abritus cracks the pass of cem by brute force method. When the pass is known key learning is no problem it is also possible with vdash.
  15. #12
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by offsystem View Post
    Hemm i'm personally not familiar with the abritus volvo system but i don't understand this. If the password is crackable via BF attack why choose the londsdor the eeprom job? In the whole word the chinese companies offer the cheapest and quickest BF server farms. (State donated cheap coal plants) They can sell tokens/logs/credits for this.
  16. #13
    Aug 2015
    Quote Originally Posted by jodge View Post
    I think it also depedns of which type of cem it has
  17. #14
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by narkeleptk View Post
    The VIDA able to programm aftermarket keys too? What about the old separate style id48 key+remote can you use used remotes?
  18. #15
    Fallen's Avatar
    The Abritus method can take up to 7 hours to crack, its not a viable option.
