kess v2 problem writing gran cherokee 3.0 crd
Results 1 to 11 of 11
Hybrid View
    Oct 2014
    Default kess v2 problem writing gran cherokee 3.0 crd
    hello all, i have a reworked kess v2 fw 4.036 and sw 2.08, i can read and made id to the car ( gran cherokee 3.0 crd) but when i try to write the modified file a error appears saying: error checksum buffer, checksum is corrected with winols I have checked it several time but nothing changes.
    does someone know if problem is on the tool or maybe is not a supported model?
    thanks!
  2. The Following User Says Thank You to ivanrojo For This Useful Post:
    abdomm (21st March, 2017)
  3. #2
    Mar 2017
    Russia
    Problem in your software.
    Oct 2014
    it is sw 2.08 i had tried with 2.24 and same problem, with other cars never had any issue, any advise?
  5. The Following User Says Thank You to ivanrojo For This Useful Post:
  6. #4
    Oct 2014
    Well, for sure my kess is not ok, today I tried to read a c4 2.0 hdi 136 dephi ecu, and i couldn?t kess said protocol error , I read a golf v bkd without problem but when i tried to flash it kess said error and ecu was bricked... I could rescued it with mpps v13.
    Same thing happend with other bkd before reworked and sw 2.24, with new eu components and 2.08 and new libraries for sd nothing chagges...
    i don?t know what to do, i?m thinking to buy a galleto or other tool which works better.
  7. #5
    Oct 2011
    i think problem is in your reworked kess not softwere
  8. #6
    Oct 2014
    the strange thing is that it does the same as before rework...
  9. #7
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    if you cant trust it bin it , not worth the risk , best get a good eu clone , or mpps 18
  10. #8
    Oct 2014
    you mean a mpps 18 clone? or original?
  11. #9
    Oct 2014
    could be for using a wrong protocol? i have just noticed that my kess has 3 protocol for this car!
  12. #10
    Senior Member Novik_UA's Avatar
    Jun 2010
    You can try write mod without correction CS in WinOls, sometimes it help. Kess will calculate CS before writing.
  13. #11
    Oct 2014
    I tried and nothing change today i try to write a bkd, edc16 c31/c34 read it good but when writing kess brick the ecu, and this message appears:
    it means: have been found a writing error turno off ignition, do you want to do recovery mode?
