Results 1 to 13 of 13
    Aug 2015
    Default a3 8P can bus wake up
    Can someone help me i need canbus wakeup signal to get cluster on bench working
    diagnostic is working but wake up signal is missing
    Wake up is coming via CAN from central electric
    If you have CAN logger you can send the wake up CAN message otherwise get central electric
  3. The Following User Says Thank You to exe123 For This Useful Post:
    offsystem (20th March, 2017)
    Aug 2015
    Do you have the cansignal logged maybe? I have sniffer.
    Must i sniff the message from Kombi can by the Cluster?
    Dec 2013
    Send this to the bus : ID:575 DLC:2 DATA: 07 00 every 200ms
  6. The Following User Says Thank You to ungask For This Useful Post:
    offsystem (21st March, 2017)
    rob h's Avatar
    May 2011
    pressing the time button might do something
  8. #6
    Aug 2015
    Quote Originally Posted by ungask View Post
    Not working
  9. #7
    You need to send this message on KOMBI-CAN. It will not work via diagnostic CAN
  10. The Following User Says Thank You to exe123 For This Useful Post:
  11. #8
    Aug 2015
    Yes is working now thx
  12. #9
    May 2013
    United Kingdom
    need help with can messages to power on TT 8S virtual cockpit cluster
    i have VECTOR can lin interface to send can messages
    will pay for all infos if is necesar
  13. #10
    Feb 2018
    I send ID:575 DLC:2 DATA: 07 00 every 200ms to can (pin29/pin30), but dash did not power up. With pressing the time buttons itīs possible to connect to vcds or other tool, so the wiring in general is correct. Only something with the can message for ignition is wrong.
    Is sending can message to pins 29/30 (can high/low) correct?
  14. #11
    May 2013
    United Kingdom
    Id 3c0 message 00000300
    Append 00 00 00 00 in case you need 8 bytes
    your ideea is correct only for OLD clusters ID:575 DLC:2 DATA: 07 00 every 200ms
  15. #12
    Feb 2018
    Got it, it was a bad mistake.
    Send ID:575 DLC:4 DATA: 07 00 to cluster via can and it worked.
  16. #13
    Top Poster tec.guilherme's Avatar
    Brasil
    Hi guys I pay for information and code in ARDUINO, I need wake up this cluster in bench, if possible help me here.
    The corrects is what?
    Because I order parts I plug all BCM 3 Conector Bordnetz Instrument Cluster and Gateway, only when input Line 15 display at clock and mileage still on for some time and later need off and on our press bottons for show.
    I need wakeup cluster for see display.
    The correct Frame is:
    Mr Krakers told: Append 00 00 00 00 in case you need 8 bytes
    Please any one can help.
