Results 1 to 3 of 3
    Fr
    Default 307 1.6 EDC16C34 DPF Off Help
    Hi guys I made a dpf off with the switch solution on a 307 1.6 , I reset the additive value and made change dpf and deleted the errors before extracting the bin from ecu , but I have lot's off weird faults now . It's the first time happening this ,I already made some friends cars and never have a problem so don't know why now. Can someone make a dpf off and dtc delete P1435 P1445 P1446 P2408 or just delete the dtc's ,thanks for your help.
    Jun 2012
    dtc P1435 P1445 P1446 P2408 off, fap off
    test and report
    no pass
    Click thanks
    9662872280_dtc P1435 P1445 P1446 P2408 off.mod.rar
  3. The Following User Says Thank You to javiere For This Useful Post:
    Freezzby (23rd March, 2017)
    Fr
    Hi javiere tanks for your help just 2 off dtc are active with your file : P2408 and P1435 .
    It was finally solved ,thanks
