silca rw4 or silca rw4 plus
Results 1 to 13 of 13
    Dec 2009
    scotland clydebank
    Default silca rw4 or silca rw4 plus
    silca rw4 or silca rw4 plus what is the difference with this 2 machines can they both be upgraded to id 48 cloning and can both use the same electronic heads thank you as think of buying one as id 48 not being released on
    jma and do not know if ever released thank you.
    Dec 2010
    Nottingham
    RW4 plus has id46 cloning built into it , rw4 doesnt and for id46 on rw4 you need the p box for id46 cloning .
    the m box can be added to both for id48 cloning .
    best bet is stick to rw4 plus as id46 is built in , and if trading in even an old cloner the price can be heavily discounted
    keyline ultegra or keyline mini with extreme kit offer same coverage but with mini you need internet connection for 4d and 46 cloning , with ultegra its stand alone and like silca only id48 needs internet
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    godfathertre (23rd March, 2017)
    keyprogramming's Avatar
    May 2010
    Quote Originally Posted by godfathertre View Post
    The RW4 Plus has ID46 P-BOX integrated.
    NWKeys had a cracking deal that finished 31 DEC.
    RW4 Plus + M-BOX for ?999+VAT but you had to part-ex any old existing cloner.
    I found an old basic Chinese cloner that I'd had for years.
    Included in the deal was 10x GTI chips, and 10x T48 chips which on their own are ?200, so the units only cost around ?800+VAT
  5. The Following User Says Thank You to keyprogramming For This Useful Post:
  6. #4
    mikajna's Avatar
    Mar 2015
    And main difference now is that last update is not released for RW4, only for RW4+, maybe they quit support for those old machines, will see when next update came out...
  7. The Following User Says Thank You to mikajna For This Useful Post:
  8. #5
    newone's Avatar
    Oct 2016
    rw4 is the old model that replaced with rw4+ some years ago,does not use electronic heads anymore,those replaced by silca gti chips,you can search for a fresh stp program and find easily what can do and with what chip
  9. #6
    szengen's Avatar
    Jan 2017
    Poland
    This device is very good, but only for cloning the key, you do not have a key do not make a key
  10. #7
    Dec 2009
    scotland clydebank
    silca rw4 latest software i just bought one version 2.00 software i am trying to update with silca software wintransfer trough usb port driver okay keeps giving me error can somebody which has the machine check what is the latest software for this machine
    thank you .
  11. #8
    newone's Avatar
    Oct 2016
    04.02.086 latest rw4 firmware,when you try to update you must choose correct port,if so you will see the serial number of the machine then you can proceed
  12. The Following User Says Thank You to newone For This Useful Post:
    godfathertre (26th April, 2017)
  13. #9
    Dec 2009
    scotland clydebank
    trying to update silca rw4 machine for last 2 days is driving me mad under device manager says usb serial port 3 using silca wintransfer got a driver from member newone update keeps saying wrong machine and not bringing up serial number download update
    and says the type of machine is different from the set one i selected rw4 i am losing my mind could the driver maybe not installed right can somebody check that has the machine if is listed under silca usb serial port and could the machine be updated any other way
    thank you
  14. #10
    newone's Avatar
    Oct 2016
    from stp you choose machine table then hit new,then you remove serial camble from the rw4 and add machine,after hit update
  15. The Following User Says Thank You to newone For This Useful Post:
    godfathertre (28th April, 2017)
  16. #11
    Dec 2009
    scotland clydebank
    need skp key programs complete if somebody has thank you
  17. #12
    newone's Avatar
    Oct 2016
    you dont need skp,only stp,is ok for rw4
  18. #13
    Dec 2009
    scotland clydebank
    still not resolved says the type of machine is different from the set one if someone can help otherwise will need to send to silca for upgrade and will not be cheap thank you .
