Results 1 to 14 of 14
    Mar 2011
    Default pinout bmw 418d 150hp ktag
    I have one bmw 418d 150hp. I have ktag 2.22 with firmwar 7.020. But in type ecu, I don?t have this. Someone can upload pinout to connect to ecu.
    mariusica_boy's Avatar
    Jan 2010
    Quote Originally Posted by alcorte View Post
    From Fgtech.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following User Says Thank You to mariusica_boy For This Useful Post:
    alcorte (23rd March, 2017)
    Mar 2011
    Ktag need ribbon cable 144300T105 In your picture is different to ktag.
    Thank you.
    Mar 2011
    duplicate.
  6. #5
    Aug 2009
    Ecu is edc17cp50, GPT.
    Send you mail, i dont can put the file help in f?rum.
    Br
  7. The Following User Says Thank You to gezame For This Useful Post:
    alcorte (24th March, 2017)
  8. #6
    Mar 2011
    I send my email.
  9. #7
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by gezame View Post
    Br
    It is in ktag software and shows you using boot cable and coloured ribbon cable also prob 3 variants of that ecu so compare with photos ktag gives to see where yellow & orange are located for ribbon cable
  10. #8
    Mar 2011
    orange calbe.jpgThe file does not have this ecu, Does not match any of the 3 versions. And I do not want to experiment with this ECU with gpt.
    Plug-in 668: EDC17 C50 IROM TC1797 Hardware 1 , This hardware is similar, but the orange wire is not the same. Mine has 3 holes, and in the photo has two holes.
    The file is 06/2016.
    Someone....
  11. #9
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by mariusica_boy View Post
    From Fgtech.
    m8 do you have a pdf with all tricore pinouts ( grey boot wire)? if you have can l have a copy ? be useful for my mpps 18 , cheers
  12. #10
    May 2016
    you need gpt connection firmware 7.020 dont have active gpt plugin
  13. #11
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Someone....
    There is 3 versions of that ecu same as 3 series 2012>
  14. #12
    Mar 2011
    Quote Originally Posted by tricore3 View Post
    I appear to me as activated in the protocols.
  15. #13
    Mar 2011
    Quote Originally Posted by teerak2uk View Post
    I do not want to take the opposite, but there are more than 3, you see the photo of the ecu than I upload. It is different from the 3 you mention.
  16. #14
    Aug 2009
    Quote Originally Posted by smirnoff_rules View Post
    See this, is for orignal fg.
    Br.
  17. The Following 3 Users Say Thank You to gezame For This Useful Post:
    rafal (15th August, 2019), smirnoff_rules (25th March, 2017), urcarpc (1st July, 2020)
