Results 1 to 13 of 13
    BALI7605's Avatar
    Brisbane QLD
    Default W203 EIS mileage
    Hello All,
    i do a crazy job again (well it is crazy to me) i building a w203 from scratch here is the EIS which is from another car.
    In live data shows 231244kms but the car i'm fitting it is only on 77000km can some one please calculate the milage for me.
    The mcu s are 1J35D
    Thank you,
    bali
    here is your file
  3. The Following User Says Thank You to nikz For This Useful Post:
    BALI7605 (26th March, 2017)
    BALI7605's Avatar
    Brisbane QLD
    didnt work car wont start key not recognised. i put original data back and working
    Jan 2013
    try this
    reseted to zero
    i think nikz file is right too
  6. The Following User Says Thank You to rocko For This Useful Post:
    BALI7605 (28th March, 2017)
    BALI7605's Avatar
    Brisbane QLD
    Default thank you
    The Rockos file worked fine. i dont understand what happend with Nikz. Guys i need one more help please.
    The dash i can not get the mileage rigth. I try to make it 127000kms its a 93c86. I tried tachsoft and carprog but none give me the rigth number.
    Can someone make it 127000km please.
    Thank you
  8. #6
    antenor's Avatar
    Here
    Here you have....
    If i help, d'not forget to press thank button!!
  9. The Following User Says Thank You to antenor For This Useful Post:
    BALI7605 (29th March, 2017)
  10. #7
    Above sea-level
    Which of the 2 MCU's contains the mileage? Connector side MCU?
  11. #8
    sida's Avatar
    May 2014
    System32
    Attachment 439081
    Quote Originally Posted by budG60 View Post
    this one
    one from DK member tested
    Attachment 439082
  12. #9
    BALI7605's Avatar
    Brisbane QLD
    mcu1 is correctly has the mileage. I dont know why it didnt start witn nikz data but rocko 0 milage is correct and worked perfect
  13. #10
    Above sea-level
    Quote Originally Posted by sida View Post
    Attachment 439081
    this one
    Attachment 439082
    which picture is "this one"? :-)
  14. #11
    Shmortz's Avatar
    in the middle of nowhere
    first picture, MCU I 220 immo data
    second picture, MCU I 130 mileage
  15. The Following User Says Thank You to Shmortz For This Useful Post:
    budG60 (31st March, 2017)
  16. #12
    Above sea-level
    Did anyone manage to read the 1J35D I130 with UPA?
    I have lifted the reset pin, but keep getting reset high error!?
  17. #13
    Above sea-level
    Nobody ever managed with upa? Security bytes?
    Verstuurd vanaf mijn SM-G900F met Tapatalk
