Compare, try and report.
Hello, cano someone make working immo off on this car? ECU nr. 0 281 011 505
solutions ECUVONIX , SCP, tested, but engine revs to 3000rpm only.
thanks all for help
0 281 011 505 _multipla_23.3.2017.zip
GS
Best regards.
Dragon
thanks, but not working. car dont start.
GS
emulator is last choice, do You have flash+eep working solution?
yes, i know, but i thought solution from boxer/ducato jtd that uses the same type of ECU can work on 1.9JTD too..........probably not....
write original eprom file and write this flash in ecu but only boot mode or with programer.not true obd.pass in pm
WinOLS (Fiat Multipla (immo off,dtc off cheksum) - 371883).rar
alejandrobr1995 (2nd June, 2017), elitricista (24th October, 2023), gejzaslapka (26th March, 2017), grip599 (20th December, 2020), hellmet (8th August, 2023), johnny s (28th August, 2019), mancinofranco (5th February, 2018), Sim0o0 (5th February, 2018)
thanks guys, try it tomorrow
working well :-)
Thank You again
GS
can I have a pass please...
thanks...
thank you vlaki electric
Password thanks
