Results 1 to 4 of 4
    castin's Avatar
    Oct 2015
    Default Key cut machine low cost 998C from China
    Hi. Need any info about this machine. Need low cost for begining and need to now did this cutter cant copy HU66 VW key? Thanx
    Jul 2016
    New Zealand
    Do not waste your money on cheap shit! Buy a good tool if you want to be professional! When I start working on keys cutting, I bought 368A (the same machine with a different name). It cut two keys and the motor bearings collapsed. The clamps are too deep and the keys do not fit into it properly.
    Aug 2016
    I started with one of those and it's not that bad. Just make sure you change the bits for decent quality ones, and when you cut a key go slow and cut in a couple of layers.
    Sent from my HTC One M9 using Tapatalk
    castin's Avatar
    Oct 2015
    Thanx for info, i want cut key 3-4 per mount, im not locksmith, only for immo key fob. I now, good tool must cost, but meybe its ok. For good tools like a Silca etc. im must pay 800 - 1000 Euro - used tool.
