Results 1 to 2 of 2
    Anzelmas's Avatar
    Stockholm, Sweden
    Default Porsche Cayenne S 2005 used PSM recoding
    Hi, m8s!
    Can somebody explain how to recode the used ABS Control Module for this car. Original coding was 21766, donor - 21765. But the new ABS CM doesn't accept the original coding. It accepts codings from Toureg and the car even starts, but all the time I get the fault code 01044: Control module incorrectly coded. I have tried with VCDS and FVDI, but no luck.
    7L0907379C Ate MK25
    Did you solve this problem?
    I have the same
