You may try swap eeprom if not corrupt.
hi lads , l have a friend at another garage and has a 2008 corsa with dead airbag ecu ,
if l get a used one with all the same numbers is it plug and play ?
if not can l swap eeprom over ?
if so which eeprom is it and whats type
cheers
Best regards.
Dragon
smirnoff_rules (28th March, 2017)
which eeprom m8 on that picture ? and you know what make eeprom is just in case
95160 eeprom ....
Best regards.
Dragon
Send me dump , I clear it for you ...better original with original vin ...
Best regards.
Dragon
l think ecu is faulty m8 , car hasnt had a bump ,
then change srs unit and use opcom for clear errors ...
Best regards.
Dragon
owner hasnt security number ,
Read eeprom from odometer or from ecu and I tell you pin code ...change srs unit maybe will be ok
Best regards.
Dragon
dosnt look like many selling unpaired units so this is what made me think there plug and play
or just swap eeprom over ?
Try plug and play and use opcom for clear errors only ...
Best regards.
Dragon
dont want to guess really just need to know if its plug and play ,, dont want to order one and waste mates time if it needs coding
If same numbers ecu and all numbers then plug and play, but never sure 100%.
Best regards.
Dragon
this is from an ebay page , looks like l can swap eeprom l would think
Vauxhall Opel Corsa D Airbag ECU 13262359 *WITH PIN* (ready for you to program with necessary equipment) OR AT ?50 EXTRA 'Plug & Play' (Bench programmed)
Good working order
Price includes this units PIN number so it is ready to program with tech2 / Opcom
OR we can transfer data from your unit to this unit - to do this you will have to send us your old unit, then this unit will plug straight in and work with your existing keys with no further programming necessary. The charge for this service is ?50inc VAT extra - please contact us on how to pay for this service if needed. (Our address to post your unit is below)
Price includes UK delivery and VAT, a UK VAT receipt is supplied with your order.
It looks good ...
Best regards.
Dragon
