Results 1 to 15 of 16
    Apr 2016
    uk
    Default need help with polo 9n 2002 please
    hi
    i have immo light flashing.tried to program key and ecu does not accept it.
    tried to diagnose ecu but was not possible to conect with ecu.
    connected with cluster and get error ecu blocked.
    bought another used ecu,swap eeprom but got same error and still cannot program keys.
    ecu m. marelli iaw4mv.dd
    eeprom 95080
    read with upa as st95080
    please help
    95080 ori.rar
    thank you
    Oct 2015
    have you communication with new ecu? if not than check fuses, wires, power supply of ecu...
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  3. The Following User Says Thank You to rokibar For This Useful Post:
    comizelu (30th March, 2017)
    Apr 2016
    uk
    Does not communicate ..tried to diagnose but no communicate
    Inviato dal mio HTC One utilizzando Tapatalk
    Aug 2012
    check on obd pin 7 kline what volltage
    have u communication with any other ecu instrument or radio
    relearn immo over instrument cluster
    have done many time
    this is another eeprom i have found on net
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    kiszka's Avatar
    Apr 2016
    uk
    Voltage 10.61
    I have 2 ecu- original and used.no communication at all.
    Cannot relearn immobiliser.fails
    Apr 2016
    uk
    File is for..?
    kiszka's Avatar
  10. The Following User Says Thank You to kiszka For This Useful Post:
  11. #9
    Apr 2016
    uk
    Cannot communicate with ecu.immo off can be done?
    I looked on dk and not possible?
  12. #10
    kiszka's Avatar
  13. The Following User Says Thank You to kiszka For This Useful Post:
  14. #11
    Apr 2016
    uk
    Other
  15. #12
    kiszka's Avatar
  16. The Following User Says Thank You to kiszka For This Useful Post:
  17. #13
    Aug 2012
    Quote Originally Posted by kiszka View Post
    Remove, check the diagnosis
    i think that is the problem :-)
  18. The Following User Says Thank You to icezero2010 For This Useful Post:
  19. #14
    Apr 2016
    uk
    Tried..nothing.
    It was fitted 2 years ago.
  20. #15
    Aug 2012
    Tried..nothing.
    ok can u connet ecu on bench and test comunication
  21. The Following User Says Thank You to icezero2010 For This Useful Post:
    comizelu (31st March, 2017)
