Results 1 to 3 of 3
    soxten's Avatar
    Mar 2013
    Default Liftgate module Opel cant write file correct help!
    I have a liftgate module her from Opel
    It has a mcu 9S12XD128 with mask 2M42E
    I read broken with Xprog 5.6 as 2M42E and get Eeprom and flash file.
    I write flash to a NEW virgin modul and no problem!
    But on Eeprom i cant write all file... I get verify error on line 000000803H ->> all time!
    I have try to lift pin, change place for ground (-) but no diffrent...
    What make this problem for me?
    I ser that Xprog read/write it as 9S12XD256 with mask 0M42E but it is a ...XD128 mask 2M42E mcu on pcb
    Partnumber is 20837686 on NEW and 13325520 on broken/used
    Skickat fr?n min iPhone med Tapatalk
    danyguit2000's Avatar
    Earth
    Have you tried to load only the eeprom (delete flash and load only eeprom) ?
    You'll be better off if you swap MCUs over...
    soxten's Avatar
    Mar 2013
    Solved it!
    Upa-usb-s did read ...128 so I did get correct files.
    Xprog read this mcu wrong!
