mikroel (31st March, 2017)
carprog clone can't clear chrash.u have to clear it manualy
Not true..he can do 95% things in 8.21 soft..I have 3 clones and they do all crash data from airbag.Cheers20170317_205126.jpg
Did you reprogram your clones yourself or did they come like that? That wire from mcu to ground is put there after wiping and flashing atmel mcu.
There are 2 different clones out there. The original clone with serial starting with number 8 which works only with software version 4.01 and the 8.21 clone which has different serial and supports online functions.
Also, CarProg software v9.xx+ connects to online server when you search for crash. I don't like the feature because sometimes I'm out where I have no WiFi and have to use an older version that doesn't need WiFi but doesn't support some newer modules.
I have original and a few old clones, I do not have V8.21 clone that supposedly supports all online functions like programming MAC and Infineon. Can someone tell me if it actually works?
Hi.All three clones are 8.21 firmware and soft. I did by my self. antena works very well from peugeot 206 (20om) and whole options to reprograming ..2j74y mask flash progres on picture and in circuit 0D66J HC08 Airbag. 20170316336.jpg20170317_205126.jpg20170322350.jpg20170322353.jpg
repairmymodule (24th April, 2017)
How about reading and writing Mac and Infineon processors since it usually wants to connect to codecard server to retrieve the Security Bytes to access and dump modules data block
Thanks for your reply
