Check driver, maybe a little hole in it ...or if no hole in the driver try this medicine ...
Best regards.
Dragon
Hi.
are you can repair DTC with dragon 100 clear file?
I got the similar problem Mazda 6 Airbag sensor DTC U3003.
Hey guys ... Mazda6 U3003 also ... is this dump problem ... im guessing that is HW problem ... Does anyone fix this ?
I fix this problem. U3003 is HW problem ....
