Ive tried nec from rcd310 and it works. Also tried a nec from my scrap boards and it works. I use only uart mode
m3touk85 (7th April, 2017)
i was trying read RCD 310 , without success , i always read it with CG-100 , can you please send me how you use it for reading ????
may be im doing something wrong
I use this connection.
cjawahir (17th April, 2017)
Only 4 wires ???
Is Mose refer to PDX ????
By cig-100 I use 6 wires
Yes mode=pdx. Only 4 wires for uart mode. For spi mode need more wires
Still can not read , before I was able to read with Cg-100
here is pinout i use before with cg-100 to read it
Try to switch rx with tx and try again
on your orange try to fix the wire connexion. i had this probleme before
it's my pleasure to help you
garabounga (26th April, 2017)
Thanks I swap tx with rx works fine
