Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Mar 2013
    Default VuDuo wont start following day
    My VuDuo wont start with the remote after the following morning when I get up. I have to reboot from back of box again to start any issues why this might be?
    I have EPG set to run at 4:00 in mornng using crossepg and save to HDD.
    Never had this issues before. Done a reinstall flash a few times but problem comes back again.
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Epg is more memory intensive on older boxes now and can cause a few problems.
    I'm assuming you are using vix image and it seems to be epg causing problem try creating a swap file from main menu>set up >vix section.
    If not that then turn off automatic download and see what happens tomorrow.
    May have to do a full reflash and re do new settings from start again.
    Junior Member tristan2000's Avatar
    Jan 2012
    I have an ongoing problem with CrossEpg causing receiver to lock and crash. When this happens the only way to restart box is via the on/off switch. This was happening more often when I used to run Automatic search at 4:00 am like "unodat". Nowadays I run EPG manually but this problem still occurs. The other issue is that Telnet is not recognised during this occurance. The only time Telnet works is when the box is working OK and I am able to send any command eg opkg etc. and safely restarting box. In other words when I need to use Telnet it is not recognised. I have now deleted CrossEpg and only use EPGImport, When I was using the two epg’s could this be causing this problem?
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Telnet won't work as box will be frozen. As you said box working on epg import I assume it's set for Rytec UK xmltv on sources. So clear configuration settings on crossepg and don't use. I assume also you don't have epg saving to internal flash as this would create problems.
    Jan 2012
    I confirm that I am using " Rytec XML TV" for the following: France/Germany etc/Italy/Poland/Spain and UK XML TV. CrossEpg Plugin has been removed (I looked in Dream Explorer and can't find any reference to CrossEpg) EPG is stored in media/hdd. Do you say that it is normal that Telnet will not work when box is frozen? I thought that one of the advantages of Telnet was that it will restart/reboot your box when things wrong wrong?
    Jan 2012
    I tried experiment last night. manually ran both EPGs last night, no problem. This AM run auto run EPG for EPGImport at 4.00 am and CrossEpg at 6.50 . This morning box was stuck and non responsive and clock at 6.50 approx (front panel is set for non scrolling)
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Quote Originally Posted by tristan2000 View Post
    Why would you want to telnet when the rocker switch at rear of box can be flicked to restart it? No doubt when the box can't cope with operations because of inadequate ram and processor power it will freeze just as older computers do as well nowadays.
    Jan 2012
    Quote Originally Posted by DOUGALMCD View Post
    I thought it would become “bad practice” to continue (this makes me sound like I’m at work) to use the on/off rocker switch (actually I use the mains plug switch, because it is easier to get to). I now have given up on CrossEPG and only use EPGImport/Rytec. The box still locks up with CrossEPG. This morning around 10:00 am I setup Rytec and 11:00 am CrossEPG with no problems. Then in the afternoon set them up again and CrossEPG caused the box to lock. I've had enough of CrossEPG all together! BTW on another forum there appears to lots of messages about boxes locking during EPG
    Sep 2008
    i have 5 boxes all on openvix and use crossepg and have no issues at all but i save mine to external usb and never had issues,vu duo is an old slow box needing swapfile and cacheflush in use.
    powering off and on the duo might end up with on and starting with red light of death.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    @ op you need to turn off crossepg over night. If box is responsive next day then yes it's related to crossepg.
    Most of the problems I've read here are more than likely bad memory units be it hdd or usb
    Jan 2012
    Maybe I should have mentioned beforehand​ my box is a Miraclebox, and the epg is saved to 1tb hdd with 88% free disk space. Tonight I will only run Rytec at 4.00am and see how it goes.
    Jan 2012
    Before I go I want to thank all for your suggestions.
  13. #13
    cunny's Avatar
    Jan 2009
    The Shoutbox
    If I was you, I'd totally disable epg. I think your hdd is at fault regardless of image/box manufacturer
    Cunny
  14. #14
    Jan 2012
    Quote Originally Posted by cunny View Post
    Cunny
    Really, the hdd still records and playbacks, image backups still work no problem, maybe I should save epg to usb??
  15. #15
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Have you tried a different imageand not reflashed the same 1
    And epg.data set to hdd?
    How about channel scanning? Is that set to over night?
