Results 1 to 7 of 7
    Member Technophobic's Avatar
    Mar 2016
    Up North
    Default Switch config causes crash
    I don't want to fracture any rules so will attempt to explain. Upgraded to Open ATV 6 but when I try to switch I get a BSOD. I have an old 5.1 version of Open ATV and this doesn't happen, but that is getting dated, cannot update it anymore and it is fraying at the edges, so wanted 6 to work.
    The box is a clone X solo mini v3 but I don't think that is the problem.
    Any clue how to fix this?
    Mar 2016
    Up North
    Quote Originally Posted by Technophobic View Post
    That's part of the Softcam Panel in case I was being too cryptic. I can't be the only one experiencing a crash.
    Surely?
    Mar 2016
    Up North
    Surely?
    EDIT: Gonna try OpenVix
    Mar 2016
    Up North
    Tried OpenVix but I do not like that image. So I am back on OpenATV, and hoping, once again, for a solution to the BSOD. I can't post on their site as the team do not support cams, so won't entertain queries about crashes caused by their use. I have seen someone ask in the past.
    I wouldn't even mention the word clone.
    Oct 2008
    try openpli 4 regards jovie
  6. The Following User Says Thank You to jovie For This Useful Post:
    Technophobic (10th April, 2017)
  7. #6
    Mar 2016
    Up North
    Quote Originally Posted by jovie View Post
    Tried it yesterday mate. Either I had a bad image, or, it has rapidly gone downhill. It took an eternity to update packages and I noticed some other changes from the last time I tried it. It would only give me two cams to choose from, tried installing the usual feed but those wouldn't show up in the menu? That image used to be the most straightforward, it was my first image.
  8. #7
    Mar 2016
    Up North
    From what I have experienced from other images recently OpenATV has to be the one. It is no contest. Can anyone interpret crash logs? I have one for the events.
