Results 1 to 7 of 7
    Apr 2017
    New Jersey, USA
    Default Help 2013 Chevy Equinox Airbag codes
    I need help getting rid off these codes. I use Autel DS708, I replaced the sensors requested by the codes and the same codes come up.
    I replaced this vehicles original airbag module with one that I bought with the airbags I replaced. Can anyone help find the problem, I was told
    that maybe the used module may be corrupted. I have the original module but I do not know how to clear the data on it. For some reason I cannot upload the pictures. Here are the codes I`m getting B0086-04 Dtc current status current Right front side impact sensor open, B0088-04 Dtc current status: Current Right Rear side impact sensor open, And B1001-00 current satus: Current Option Configuration. Module number is GM 13589377.TIA
    FxShaw's Avatar
    Nov 2013
    Outta This World
    You made it a lot more harder by replacing that airbag module...put back the old module and fix the error that shows up.
    🔥Wacka Wacka 🔥
    Apr 2017
    New Jersey, USA
    Thanks for the response, if I put back the old module what can I use to delete the crash data? I have an Autel 708 and carprog but I`m new to all this and I want to learn as much as I can beacause I started dealing with salvage cars.
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Autel will do it... and even carprog have a obd option for gm...but you are good alone with autel and this car.
    🔥Wacka Wacka 🔥
  5. The Following User Says Thank You to FxShaw For This Useful Post:
    dualboot (11th April, 2017)
    Apr 2017
    New Jersey, USA
    Will do it with Autel thank you.
    epd1221's Avatar
    Nov 2011
    usa
    have you check wiring from module to sensors ??? sounds more like wiring issues you are having autel should clear no problem if no issues are found
    Feb 2011
    Land of Opportunity
    I had the same issue as posted here. The B1001 code: Option Configuration Error. Found the issue with the BCM was bad and once that was programmed the airbag light was off.
