charlie567 (13th April, 2017)
If you loaded Catseye channel list via Dreambox edit and then decided to download Vhannbals plugin and update via the plugin then yes Vhannibals list would overwrite Catseye, with Vhannibal Plugin it really is made for the lazy person Press green button for plugins choose Vhannibal updater and then choose the channel list you want to download to the box everything takes about 20 seconds and your done, Faster than getting to a laptop loading DBedit then firing over a channel list.
if you set Vhannibals plugin to Autoupdate it updates without you lifting a finger
I have got dreambox edit downloaded and the catseye motorised list
however you have mentioned the Vhannibals plugin here
http://www.digital-kaos.co.uk/forums...o=file&id=2959
sorry to ask but how do you install this plugin ?
is there a download section in one of the openvix menus and from this l can select this plugin or simply Download the plugin from your link then install in which folder ?
thanks again for your patience
you can download the Plugin directly from the Plugin feeds, or install the .ipk from the link and let it upgrade from V 1.1 to 1.4.
I dont use OpenVix sorry so i assume the Vhannibals plugin is in there feed
thanks again.
I have got the box, loaded the channel table but struggling to get any signal on any channels
I left the old box on 0.8 west
powered the edision, set the long and lat for birmingham
but when l look for 0.8 west - its slightly out
when l go to positioner setup and move it so l get signal, everytime l come out of the menu, it moves the dish again, so l cant find any signal
I cant save the setting once l come out of the menu...which is frustrating. I cant seem to save the position of the satellite when the menu is exited
If l try and switch off USALS, the dish does not move in Disqec 1.2 setting
the satellite signal is displayed in the top corner - assuming it means the dish is moving. Really struggling at the moment to get any signal on any channels....
any help would be appreciated to get the usals working please or Disqec
update.....just seen the green store button after moving dish...gutted...
will try 13 and see if l can tune that in and then 16, 19 and 28.2
Looking a bit better now, stored 28.2 east and 13 east :-)
Last edited by charlie567; 13th April, 2017 at 05:17 PM. Reason: maanged to store channels
If using Diseqc 1.2 you have to use the Advanced option in the Tuner Configuration setting and then number differently every satellite you want to store so say 13,19,23,28 etc..
Then goto the sat finder and move dish in small increments either east or west until you find the best signal for that particular satellite once done make sure the Number of the satellite corresponds with your saved number job done
Nearly all sorted mate, thank you so much for your help
Couldnt have done this without your help!!
I will look at the bluetooth another time, main thing is to get the satellite positions stored and Sea Lion sorted out.
Didnt know that you had to download the plugin for Emulators....learning all the time here :-)
Last edited by digicon; 13th April, 2017 at 08:15 PM. Reason: Edited for Forum Rules
