Reset oil iveco Daily 2015
Results 1 to 4 of 4
    Jan 2016
    Default Reset oil iveco Daily 2015
    hi how reset oil inspection iveco daily 2015.?
    Alawigmx's Avatar
    Aug 2016
    Sweden
    Cool
    What year? Anyway follow these steps:
    1. Turn on ignition (not engine) and wait for 10 seconds.
    2. Press the gas pedal full for atleast 15 secs, and while doing this (AT THE SAME TIME), press/pump the brake 10 (ten) times. (If this doesn't work, press the brake 10 times AFTER holding the gas pedal for atleast 15 secs.)
    3. Turn off ignition, wait five secs, turn on ignition.
    If this doesn't work, try again, if you have trouble understanding, I can help you further, the only other solution would be an Iveco dealer I am afraid. (Unless CDP+ for Trucks can do this?)
    Achtung
    Press the magic button
    Jan 2016
    2015y Someone sey only service. I trying cdp+ Truck not working;(
    Jan 2018
    Togliatti, RUSSIA
    try to change parts into engine ECU.
    Parts name is "Motor Oil" or "Oil"
    I have EASY and make is without problem.
