Results 1 to 15 of 19
    Apr 2017
    Sweden
    Default Toyota Hilux 2007, Adjust Milage
    I Have a Toyota Hilux 2007 that i need some help to adjust the mileage on,
    The original mileage on this odometer is 236666 and would like to change it to 76389 since the new engine in it has this mileage.
    Im using Digiprog 3 and im trying to connect Pin nr 1 to the backside of the odometer with any success.
    I have posted pictures below since I think it may explain it better then I can.
    clusters's Avatar
    Mar 2015
    Canada
    Are you for real????
    Clean the blue crap off the chip and turn the clip around.
  3. The Following 3 Users Say Thank You to clusters For This Useful Post:
    AdrianCR (14th February, 2018), Untz (16th April, 2017)
    Feb 2016
    Moldova
    Quote Originally Posted by clusters View Post
    100%.Red wire to pin1, not to pin 5! And is besser when chip is desold or make short connection on quartz.
  5. The Following User Says Thank You to Moldovan1 For This Useful Post:
  6. #4
    Apr 2017
    Sweden
    Default The Blue crap is gone and i have turned the wires around.. But it is still not findi
    Quote Originally Posted by Moldovan1 View Post
    The Blue crap is gone and i have turned the wires around.. But it is still not finding the chip..
    Could you please elaberate how u mean how to desole this or make it with short connections on quarts?
    Sorry im pretty desperate and dont know what to to so help me out if u can.
    Apr 2017
    Sweden
    I have tried this but it can still not find it ...
  8. #6
    DashProg's Avatar
    Jan 2013
    Here
    it so easy remove the chip then clean it well after that try to read it as 16 bit
    Everything will be back in order - All my respects to DK's members.
  9. The Following User Says Thank You to DashProg For This Useful Post:
  10. #7
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by Untz View Post
    Mate, try read by eeprom and in change this
    line00: 8D11 8D11 8D11 8D11 8D11 8D11 8D11 8D11
    line08: 8D11 8D11 8D11 8D11 8D11 8D11 8D11 8D11
    line10: 8D11 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    line18: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    line20: FFFF FFFF
    or swap
    76381 km.
  11. The Following 3 Users Say Thank You to Dr. Zoidberg For This Useful Post:
    CarCity (13th April, 2017), Untz (16th April, 2017)
  12. #8
    Feb 2016
    Moldova
    Remove chip from board with hotair station (so is much safely), or with soldered iron (one side and later another side), clean the pin carefully and read chip. But this clamp from Digiprog set is real shit! Pay atention on this!
  13. The Following User Says Thank You to Moldovan1 For This Useful Post:
  14. #9
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    you dont know how to use your own tools.....I think that is the problem
  15. #10
    Jul 2016
    Planet Earth
    connection_hilux.rar
    Hope these sort out your problem :
    1. Check your clip's continuity if you persist on using clip, or
    2. Connect adapter as seen in attachment by solderring
    3. Do as Dr. Zoidberg said
    Good luck & regards
    learn, learn, learn
  16. The Following 3 Users Say Thank You to maremuruk For This Useful Post:
    jomberykaso (13th April, 2017), mangolini (28th December, 2019), Untz (16th April, 2017)
  17. #11
    antenor's Avatar
    Here
    This clip is a
    Buy a good clip or remove the eeprom!
    If i help, d'not forget to press thank button!!
  18. The Following User Says Thank You to antenor For This Useful Post:
  19. #12
    afitijuana's Avatar
    93c66
    same as tundra 2007 and up
  20. The Following User Says Thank You to afitijuana For This Useful Post:
  21. #13
    Apr 2017
    Sweden
    Quote Originally Posted by maremuruk View Post
    Good luck & regards
    Thank you very much for the pictures they helped alot!
    I tried to change the mileage, But the only thing i recvied was this following text "Check Written data - 0 KM "
    I dont want to reset it from scratch?
    i dont know what to right now, have i ruined it..?
  22. #14
    Jul 2016
    Planet Earth
    You're welcome... next time try to press thanks button and/or add reputation, there are more than 1 respected member helped you already.
    Can't say whether you ruined it or your DP is faulty, if you have other tool try to read c66 and post your dump here.
    learn, learn, learn
  23. The Following User Says Thank You to maremuruk For This Useful Post:
  24. #15
    Apr 2017
    Sweden
    Sorry i did not mean anything bad.
    Im thankful for all the help u have given me guys, but the pictures you posted maremuruk helped me the most since all of this is pretty new for me...
    i dont have any tools.. what kind of tools whould this need, is it possible to fix this with the tool i have today?
