my frıend try this..................code 0040
Hi i have radio from opel vivaro. I want to mount this radio to another car but it says on the screen connect diag tool.
Is it possible to clear something in the dump to work on the another car? renault.zip
Decode Ghost (23rd October, 2017), exbebras (13th April, 2017), foks025 (23rd October, 2017), nikz (13th April, 2017)
my xprog dont want to write to this type eeprom:/ read is ok but when i hit write its trying and give error
thanks irfa your file is working i just soldered 150ohm resistor to vdd because xprog give 5v this eeprom need 3v
irfa (13th April, 2017)
Greetings, all
I cannot download the zip file or open the images. Are these still active? I want to install a ACG-1220RF into my W202 Mercedes. I think it looks good too.
Thank you
Does anybody have a dump file for 24c64 EEPROM for AGC-1220RF?
Thank you.
Greetings, all.
I have obtained a dump file for the AGC-1220RF. However, before attempting to program my radio, I decided to read its EEPROM to see what is on there, lest it be important and I need to transfer it to the dump file.
What worries me is that the information on my radio's chip doesn't seem to be in the same locations as on the dump file, and that the security code seems to be reversed.
teraterm_log is the file that I read off of the EEPROM, while 24V01 is the dump file I want to upload.
Are all AGC-1220RFs programmed the same? Will there be a difference between not-yet-programmed and fully-programmed files?
I suppose there is only one way to find out.
Hi, have results?
