M30882FJ - reading Flash and EEPROM via E8a
Results 1 to 9 of 9
    Holtek's Avatar
    Jan 2010
    Poland
    Default M30882FJ - reading Flash and EEPROM via E8a
    I have a problem with Renesas processors. I want to read and write Flash M30882FJ processor. I want to use E8a and Flash Development Toolkit 4.09. Unfortunately, but after connecting E8a to M30855FW with RST, TxD1, RxD1, GND, VCC, I get no communication. Pin /Hold to GND, pin /WRL to VCC and pin CNVss to VCC. What am I doing wrong?
    https://www.renesas.com/en-eu/doc/pr...8a_m16c65b.pdf
    Tereksaz's Avatar
    Nov 2010
    Dark side of the Moon
    see on pdf file and connect your E8A or rx & tx
  3. The Following User Says Thank You to Tereksaz For This Useful Post:
    Holtek (3rd May, 2017)
    Holtek's Avatar
    Jan 2010
    Poland
    Thanks. Have you tested your solution? But should I not connect the rest of the e8A pins? I do not agree a bit. See the picture.
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Maybe boot password protected?
  6. #5
    Tereksaz's Avatar
    Nov 2010
    it is pdf file example.pdf from Renesas.eu
    i can use as E8a and so simple com port and all very good read/
    as example you can see on photo
    http://www.azlina.ru/image/data/Dice/dice.jpg
    and
    http://www.azlina.ru/image/data/Dice/dice_rep.jpg
  7. The Following User Says Thank You to Tereksaz For This Useful Post:
    Holtek (10th June, 2017)
  8. #6
    Holtek's Avatar
    Jan 2010
    Poland
    Thanks Tereksaz. I managed to successfully connect the E8a to the Renesas processor. Below the documentation. 100% tested, works. Unfortunately, but my CPU is blocked by ID. It was not erased. The only solution in this case is to replace the processor.
  9. The Following User Says Thank You to Holtek For This Useful Post:
    QompaQ (30th August, 2018)
  10. #7
    Tereksaz's Avatar
    Nov 2010
    what the name device with
    M30882FJ ????
  11. #8
    Holtek's Avatar
    Jan 2010
    Poland
    Toyota Navigation
  12. #9
    Tereksaz's Avatar
    Nov 2010
    i dont have it firmware
