VOLVO ViDA 2014D and emage error
Results 1 to 7 of 7
    Holtek's Avatar
    Default VOLVO ViDA 2014D and emage error
    After installing a new Windows 7 Pro 64bit and all the drivers, I installed the ViDA 2014D. I have the same error as on screenshots. How to solve this problem?
    I believe 2014d will only install on xp with min 4 gig ram
    Holtek's Avatar
    ViDA 2014D not working on Windows XP. Only Windows 7 Pro or higher. I need run this program on Windows 7 Pro 64bit. On another laptop, with Windows 7 64bit everything working beautiful. This laptop does not want to work. Disk formatted, new system. Image error as above - you can't select any module.
    Do you have sql server & browser running, not always set as default check
    with sql 2008 server configuration manager. am using 2014a & would like
    to update, where did you find 2014d
    Mar 2016
    2014d doesnt work on 64bit. at least i couldnt me\ake it running. got 2014a runds like dream
    Version I Explorer ?
    There may be a problem.
    Press F12 and compatibilty 7 - 8 -... etc and test
    Holtek's Avatar
    ViDA 2014D works on Windows 7 Professional 64bit. I have two computers. On the two computers is installed the same system - Win7 Pro 64bit. On one of them the ViDA 2014D works properly. On the second there are no icons of modules.
