Results 1 to 9 of 9
    Mar 2017
    Russia
    Default Update Kess 5.017
    tester is required
    NXP isn't blocked
    Aug 2008
    what you mean tester required?
    you want to send dump to someone to test on their kess?
    we can test. what is about ?
    tehnosoftex's Avatar
    Romania
    Put the dump here and some one will test it for sure.
  5. The Following User Says Thank You to tehnosoftex For This Useful Post:
    electronistul21 (3rd May, 2017)
    marsete's Avatar
    Oct 2010
    SPAIN
    Hello friends,this update 5.017 is posible...is more protocols,new for read and write denso toyota and more,harley davidson with delphy ecu read and write.I very very interesed for hex file and sd files!!Regards
    Aug 2016
    you need an old computer with port com and soft flash magic to read nxp. but this work if the mcu is not blocked
    it's my pleasure to help you
    electronistul21's Avatar
    Nov 2011
    galati,romania
    Quote Originally Posted by hk06 View Post
    what interface use for read MCU NXP?
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
    Aug 2016
  10. #9
    As far as I know, you can only read if you have crp0.
    If you have crp1 crp2 or crp3 you can not read.
    Find something to move from crp3 to crp2, but I have not tried it.
