maruti (20th April, 2017)
You can try...not make it work...
Professional BMW immo solutions
Macedonia is one and GREEK!!!
hello
i go to the company , they update module & make vo coding
no fault code in egs , but same like in my workshop , car not shift in drive mode
they dont have funcation like isn match
so i want to know egs isn match in only ddf or cas4 also
You have a working set?
yes i have working full car
hello
i check with change
1] egs
2] cas4 , odo , key & dde
car working perfect but some eeror bcoz not change all module
hello
some forum member say me its may bi done with e-sys
any one know how to please tell me
Do what?
You must change vin to new modules...even if you change vin you will need fsc for egs.
hello
with autohex coding success & vin change also success but how to change isn
or with e-sys how to
if you want to change isn to cas use tool32 or hex editors...to ecu hex editors or ecu explorer
maruti (1st May, 2017)
hello
i dont have ecu explorer but i will taken from dubai expo may bi .
if any one possible with e-sys than help me
This method will bring a lot of headache to make the car OK. if the CAS is EWS5 it will be more difficult.
You must return the set back as before, and contact microtronik support, we will try to change the EGS 8HP ISN if it is supported (F10 rate is very high).
The procedure takes 7-8 minutes only. all by OBD, no dump is required.
And changing ISN in DME and CAS may not enough to make the EGS works in F series, I am not sure about this information but I hear from developers about this issue.
Probably will reflash it with virgin dump. Just like bmw explorer. And then finish job with istaP
maruti (2nd May, 2017)
