CAT C13/C15 Emergency stop
Results 1 to 4 of 4
    Aug 2010
    Default CAT C13/C15 Emergency stop
    I have a question here, do C13/C15 Caterpillar engines have an emergency stop when ECM detect low oil pressure?
    Because I?m having some problems with a few Challenger with those engines. I have recently repair an engine that ran without oil and the ECM only register 1 oil low pressure failure but the engine never made an emergency stop.
    Today another customer makes me the same question, if the electronic engine doesn?t make an emergency stops when it detect that is running with/without oil pressure.
    Thank you in advance.
    Aug 2011
    USA
    Quote Originally Posted by Khein View Post
    Because I?’m having some problems with a few Challenger with those engines. I have recently repair an engine that ran without oil and the ECM only register 1 oil low pressure failure but the engine never made an emergency stop.
    Today another customer makes me the same question, if the electronic engine doesn?’t make an emergency stops when it detect that is running with/without oil pressure.
    You have to set it to shut down with ET
    Aug 2010
    Quote Originally Posted by cnckulp View Post
    cnckulp can you tell me which option is it? I have already checked and didnt find where to.
    Thanks.
    Aug 2011
    USA
    Attachment 445541
    Thanks.
    It is in parameter under engine monitoring.
