Results 1 to 5 of 5
    May 2014
    LIthuania
    80
    Downloads
    Uploads
    Default citroen c3 2002y 1.4 hdi dtc remove p1113 p1198
    hi mates please remove fault codes p1113 p1198 car is citroen c3 2002y 1.4 hdi sid 802 read made as sid 804 but as I found out is same ecu . thanks in advance
    May 2014
    LIthuania
    80
    Downloads
    Uploads
    anyone can help ? I add read in boot mode cause first one was obd read thanks in advance
    bobolin4o's Avatar
    Apr 2010
    Bulgaria
    772
    Downloads
    6
    Uploads
    Sorry, but those errors you cannot mask just like that...
    How will work the engine if the rail pressure is improper???
    Regards!
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
    May 2014
    LIthuania
    80
    Downloads
    Uploads
    car drives normally but sometimes goes in limp mode and after few seconds goes off and drives good . this happens few times a day
    bobolin4o's Avatar
    Apr 2010
    Bulgaria
    772
    Downloads
    6
    Uploads
    Anyway...
    Fix the problem, how it should be fixed!
