smart 450 600cc strange problem
Results 1 to 8 of 8
    Gdansk Poland
    Default smart 450 600cc strange problem
    Hi Friends i have smart 450 with no cranking problem. Immo (remote) works fine. Car dont crank but when i disconnect batery for few sec. car starts - only once. Stop engine and again no cranking. Fast battery reset give me only one time starting car. After reset i can lock and unlock car and still crank (but only once) Some suggestions ??
    Jul 2013
    yorkshire
    We dont have a crystal ball to see. Do a full scan and post it here. Then we can help
    Gdansk Poland
    I need someone with crystal ball Smart give me no error. I find sam see 50 (start signal from ignition) but send mass for starter relay only once after acu disconnect. What can i do in this case? Wher can i buy crystal ball china clone??
  4. The Following User Says Thank You to adiagnostyka For This Useful Post:
    rideon (27th April, 2017)
    need one new zee module
    this car have zee not sam
    best regards
    Gdansk Poland
    Problem with clutch. Friend of mine come with sd and program clutch again and now car start every time.
    Apr 2017
    Greece
    this is a common problem,years passed and 450 smart cars are old now.
    im glad you solved it.
  8. The Following User Says Thank You to Stelaras For This Useful Post:
  9. #7
    rideon's Avatar
    RO
    Quote Originally Posted by adiagnostyka View Post
    Go stalk Meat-Head
    Quote Originally Posted by Stelaras View Post
    You should check thee clutch actuator as adiagnostyka says...
    Maybe its stuck and doesnt read the gear so if not in N ,it cannot start!
    try reading the whole thread...from post 1....next time
    A failure will not appear till a unit has passed final inspection
  10. #8
    Apr 2017
    Greece
    You are right.
    Anyway my post is edited,happy for the pal that found the issue..
