Results 1 to 3 of 3
    Default Touareg 2.5 R5 recovery for clutch/flywheel
    Touareg 2.5 TDI R5 year 2004 manual gearbox 6 speed
    A man say his 2.5 TDI R5 goes in recovery.
    He grab the car in a garage and the diagnostic say the problem is in the clutch...
    This garage also say it should be "bent flywheel that need to be replaced"
    They also say "the flywheel is sold with the clutch"
    I checked in etka and you can buy the flywheel as a single spare part.
    I tried googling for the problem, but found nothing about "2.5 TDI in recovery for flywheel"
    So it's statistic time:
    How many 2.5 TDI R5 have you heard with bent flywheel?
    Diagnostic...problem in clutch...what are they talking about?
    Could it be faulty speed sensor attached to the flywheel?
    Thank you.
    ______
    lush29's Avatar
    Oct 2015
    First no point change an flywheel well without clutch, what's the point changing only flywheel?
    Second bend flywheel i never seen... maybe he ment broken or so..
    Third is if you fell robbed or you think they are looking to screw you, call an different garage ask for the opinion and so on...
    Forth is ask for an diagnostic report with the problem or problems on the car...
    Sent from my SM-G925F using Tapatalk
    Dual Mass Flywheel (reconditioned by VW) + New clutch kit = SOLVED
    Not by me
    ______
