Password pls ....
Start XPROG-m software update...
XPROG-m firmware repaired successfuly.
Elapsed time: 00:10:04.242
[Command: Update certificate]
Start hardware...<XPROG-box>...OK.
Waiting certificate...Certificate is not yet generated. Please be patient and try again later.
Elapsed time: 00:00:26.260
Device is silent.
hello friend tried to repair my xprog..... a little help----... use vvdi prog .... but this is something different in config do not use this lock process.... thank you..
WINNER THE LOSER
Try rewriting the flash files and eeprom v5.5.5
Has anyone managed to do the update successfully, without the problem of the certificate?
Thank you
Hi all, does someone do well update his own xprog, I need to do update to 5.7 version, my 5.51
I can try to update but can someone confirm that hardware is 100% same as v5.0 pcb?
Also the software may need USB dongle or is cracked?
firmware ok but certifications no succes, reset to basic set ...
There is a decision to open AUTH-0027, AUTH-0028??? xprog-m 5.5.5
hello dear
pass please; thanks
Xprog 5.8.4 clone is opened authorization no. 27 and no. 28.
SOLVED THE PROBLEM?
[QUOTE = vanos batam; 3011362] Ici XprogM 5.7.4
Non test้ ..
Passez demander PM .. [/ QUOTE]
SVP le password merci
I add myself to the list of the "certificate waiting" problem
i have xprog 5.74 can i buy atmega 5.84 and solder that or try to reflash another version on my current sleeping atmega .....
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
