Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: XprogM 5.7.4
  1. #16
    Member chong5195's Avatar
    Nov 2016
    Password pls ....
  2. #17
    Nov 2016
    pls share pass
  3. #18
    Mar 2017
    Colombia
    Start XPROG-m software update...
    XPROG-m firmware repaired successfuly.
    Elapsed time: 00:10:04.242
    [Command: Update certificate]
    Start hardware...<XPROG-box>...OK.
    Waiting certificate...Certificate is not yet generated. Please be patient and try again later.
    Elapsed time: 00:00:26.260
    Device is silent.
    hello friend tried to repair my xprog..... a little help----... use vvdi prog .... but this is something different in config do not use this lock process.... thank you..
    WINNER THE LOSER
  4. #19
    Dec 2009
    Try rewriting the flash files and eeprom v5.5.5
  5. #20
    Dec 2009
    Has anyone managed to do the update successfully, without the problem of the certificate?
    Thank you
  6. #21
    Integy's Avatar
    Sep 2015
    Hi all, does someone do well update his own xprog, I need to do update to 5.7 version, my 5.51
  7. #22
    Jul 2014
    Sofia
    I can try to update but can someone confirm that hardware is 100% same as v5.0 pcb?
    Also the software may need USB dongle or is cracked?
  8. #23
    Jun 2012
    firmware ok but certifications no succes, reset to basic set ...
  9. #24
    Oct 2012
    There is a decision to open AUTH-0027, AUTH-0028??? xprog-m 5.5.5
  10. #25
    Feb 2017
    Douala
    hello dear
    pass please; thanks
  11. #26
    Jun 2016
    Quote Originally Posted by ketia View Post
    Xprog 5.8.4 clone is opened authorization no. 27 and no. 28.
  12. #27
    Member enriqxxx's Avatar
    Jan 2011
    venezuela
    SOLVED THE PROBLEM?
  13. #28
    Sep 2017
    [QUOTE = vanos batam; 3011362] Ici XprogM 5.7.4
    Non test้ ..
    Passez demander PM .. [/ QUOTE]
    SVP le password merci
  15. #30
    joker01's Avatar
    Jan 2018
    I add myself to the list of the "certificate waiting" problem
    i have xprog 5.74 can i buy atmega 5.84 and solder that or try to reflash another version on my current sleeping atmega .....
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
