Did you seen compression ?What cylinders are missing.
Hello to all
i need really help for BMW 7 2006 year , engine 4.5 diesel V8
I have next problem :
The engine does not work well, the right side of the engine, as if the injectors work 50% and throw out the fuel, but only to the right side of the engine. The left side works normally. There is only one mistake P1279.
I changed the maf sensors, the crankshaft sensor, checked the suction valves and checked the installation.
I tried to switch the injectors to the left to the right of the engine and the problem was the same
Please halp if anyone have any idea or have experiences with this engine and car what can be problem ???
Best regards,
Davor
Chip Tuning EGR OFF DPF OFF DTC OFF Car Electronic Repair Service !
i solved problem , no one give me correct info but i solved ...
