Results 1 to 5 of 5
    Aug 2013
    Spain
    Default Help with Megane UCH 9S12DG256 mask 1K79X
    I have a problem with this uch, im triying clone this uch in another unit with the same reference. I read the original uch without problem with orange 5 in pcb pinouts (eeprom and flash), i read the remplace uch with the same pinout, ok!. but when i try write the eeprom from original to remplace this show BOOT OK, but show me INITRAM REGISTER Write error, I try lift the reset pin, but when i try write give me MCU UNKNOW ID error.
    What is the fault? I try resold all the wires but not work...
    PINOUT from image.
    Change programmer.
  3. The Following User Says Thank You to radoslawwiklik For This Useful Post:
    carsandkeys (25th April, 2017)
    Aug 2013
    Spain
    I try with orange5, xprog and r270. i will change mcu from original to remplace.
    Romania
    Quote Originally Posted by carsandkeys View Post
    Hello power up , the unit and measure Vcc on mcu , as i know should be 3.3V and not 5 V for this mcu .
    afonso rico's Avatar
    guimarães
    try this
    for me work
  7. The Following 6 Users Say Thank You to afonso rico For This Useful Post:
    furnata (10th July, 2017), julo45 (14th February, 2023), marcolr (11th May, 2021), mexanico1971 (23rd May, 2020), paulolad (26th January, 2024), pawelelectro (13th November, 2017)
