Results 1 to 5 of 5
    reproteq's Avatar
    en algún lugar de España
    Default DTC manual remove info
    hi friends i look make manual dtc remove
    post here all info for this proposit
    when have more info tested i can make software in c or python
    free 4 alls
    __________________________________________________ __________________________________________________ _________
    for bosch edc16 i read this info is correct?
    Make the following calculation:
    ( addresses of the first occurrence - address of the associated DTC table) / 8 = index
    __________________________________________________ __________________________________________________ __________
    for siemens sid
    search dtc in hex and move octal(00 00 00 00 00 00 00 00 ) change value 01 --> 00
    example:
    p0489
    0005DED8 04 89 00 00 00 00 00 00 ‰
    0005DEE0 00 00 01 00 04 90 90 83 ƒ
    0005DEE0 00 00 00 00 04 90 90 83 ƒ
    binariman's Avatar
    Apr 2014
    europe
    I think winols can see table off dtc
    but need damos
    Nov 2012
    smartville in front of a OBDplug
    Quote Originally Posted by binariman View Post
    but need damos
    no need of damos !!
    Nov 2012
    there are Two solutions in ols to find the dtc easy
    and there is also the gouv software that tell if a dtc is on or of just applying the flash file it's says for each dtc coded by the car manufactor if it's on or off so then they can make a ticket to the seller of cars that are DTC off
    reproteq's Avatar
    ok thanks by your info
    but is posible post more info for advance in this project?
