Results 1 to 2 of 2
    Oct 2012
    Default passat b7 starter control
    hi DK, need info if anyone has experience whit this problem.
    passat 2010year 1,6 tdi 77kw
    10461-starter control-returned message
    p3053 00 50 short to ground
    after deleting errors car start to crank for 0,5sec then stop and turn on glow lamp,after that start whit no problems but lamp blinking.
    I tried to replace 2 relays for starter-same thing,check wiring and fuses all look ok
    Does anyone have anything smart to suggest what next?
    Dec 2013
    I had similar problem with Audi Q5. This car have kessy start-stop button?
    In my case it was engine ECU faulty, but as it is Passat I would check clutch pedal sensor.
