Results 1 to 5 of 5
    lush29's Avatar
    Oct 2015
    Default engine light not coming on on e53
    hi all,
    have an E53 05 and the engine light is not coming on what so ever.
    i been replacing the ecu the cluster and is still not coming on. if i run an cluster thru diag engine light come on ok,unplug any sensors or take key out put ignition on and no engine light.
    just wonder if any of you had this problem before?
    is no faults on the car either....so please need you thoughts on this. thanks
    Alawigmx's Avatar
    Aug 2016
    Sweden
    Your English is a bit hard to understand. I dont understand whether the Check engine light is on all the time or that it doesn't come on at all. When you turn on the ignition and all the lights on the cluster light up for a moment, does it light up aswell? There could be several possibilities.
    Achtung
    Press the magic button
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by Alawigmx View Post
    Ok ,engine light is not coming on.put ignition on and no engine light all other lights ok.,unplug engine sensors no still no engine light. Run cluster check with diag engine light come on. Understood?
    Alawigmx's Avatar
    Aug 2016
    Sweden
    Sorry for delay. There could be a strong possibility that the cluster has been tampered with to not report certain engine faults, I've seen this on volvos especially. Have you tried another cluster?
    Achtung
    Dec 2017
    I am also facing engine light on off problem. It is an annoying problem. Just bought a scanner and a new magnetic flashlight. I am checking total guide now. Let see if it finds the problem.
