Results 1 to 4 of 4
    Apr 2017
    Default astra j 1.7cdti dpf need to check regeneration history
    hello i just joined hopefully someone can give me a bit of advice i have opcom it goes up to 2010 its china clone from ebay it works but have to
    use engine type as wont auto detect my astra j 2011 can not check things as don't work when clicked upon
    it came up with code for blocked dpf which i took off and unblocked checked and cleaned out other valves check hose too
    now its back on need to run opcom to force regen so it doesn't block dpf again as no warning light except spanner light
    have just got vehicle its had full service have reset oil to 100%
    any help would be great thanks for reading
    Jul 2013
    yorkshire
    I suspect your opcom is too old. What version is it? Not all opcom are capable of reading Astra J.
    Apr 2017
    hi autoden
    its 201008 version can this be updated or is it buy another version of opcom
    Oct 2016
    MAKE RESET dpf and all will disppear in dpf values
