No
Just ignion on for 1 hour
Then program key again
Will sucsses
hi guys, I have a mitsubishi grandis, I wanted to program a new key but I did a reset for IMMO ECU, now the system can not program any key, do I need to write anything to engine ECU? IMMO dump attached.
I tried password 4135 and 0000, doesn't work.
No
Will sucsses
Call me on whatsapp:+966541148554
Thanks again. I read some information from internet, it seems I need to register immo ECU first then the keys, I think after the immo ECU rest some data are gone, like chassis number. there is another password to register the immo ECU which is related to the serial number. my situation is like replacing a new immo ECU now. but I'm stuck now.
Problem solved. appreciate d7mme for big help. you guys awesome
klaudio (16th November, 2018)
Nja good afternoon . big question how did you solve the problem i got same situation with a galant 2005 . erase immo ecu and cant programmed any key
I'm stuck with a grandis, is it all you need to do is write a good dump and leave ignition on for one hour? car is far away plus taking a ferry, 2.5 hours each way, does anyone have a good solution for my problem? Did a immo reset which blank the immo, wrote new immo dump and there is no sync, no dtc, remove transponder and comes with dtc for transponder. there is no spark after. will not accept 4135 or 0000 to reprogram key.
Some people just want glory instead of acknowledgment.
Thanks and reputation is earned, not ask for.
Have a nice day.
Anyone find solution?
hi i have the same problem can you help me
hi i have the same problem, can you help me
OFF IMMO-----------job done
_______________ D3-oToprog _________________
ig : vanos_batam
can you send me the immo off pls.
same issue here . anyone solve this/
