Results 1 to 7 of 7
    Oct 2014
    Default backup ktag question
    Hi all, i?m newibie with ktag, yesterday i did my first bakcup, the ecu was a me 7.5.
    Reading backup file size is 342 kb, smaller than flash reading .
    If i read only flash file size is 1024kb, furthermore when the reading of the back up ends i can choose to save in one file or in three differents files (micro, flash and eprom) if i chose to split it on three, the sizes of each one are correct (1024kb 32 kb and 1 kb ) but if i chose just one file, size is 342 as i said before.
    How is it possible??, full back up must to be 1057 kb, am i right?
    BR
    Aug 2016
    chose 3 files backup. something rong about size of one file
    it's my pleasure to help you
    Oct 2014
    On other forum someone said me that ktag encryptes full backups and that?s reason of the small size, but no idea.
    DK Veteran daniel guerra's Avatar
    Does ktag asked you to save separate files? If yes choose that option and see if the files have the same size
    Mar 2016
    Read full bdm, when done Ktag aske do save files separetly, choose yes. It will save micro, flash and eeprom(if they exsist) separetly. Fourth file is full crypted file, wich contains all information, file size does not matter it is crypted and can be used only with ktag, maybe trashdata also not sure.
    Oct 2014
    Great thanks for answers!
    Jun 2013
    EU
    Well, crypted is not the right term, better say packed. Crypt not explain size reduction, but pack does.
    And ... Me7.5 does not have BDM access, c167 micro based ecu not MPC.
  8. The Following User Says Thank You to morgano For This Useful Post:
    ivanrojo (13th May, 2017)
