Results 1 to 7 of 7
Thread: Epg
    Jul 2008
    Default Epg
    Hi guys is the epg on openbox 1 hour behind as I have to have mine 1 hour behind to get the info to match the program.
    Apr 2017
    Did u change time on your box whens clocks altered
    Apr 2017
    Menu button . system setup . epg time settings . change to summer
    Jul 2008
    Yes I put the time right but the info is 1 hour behind,am I doing something wrong
    Apr 2017
    Quote Originally Posted by chuckles53 View Post
    I get the same, changing the time & changing Daylight savings from on/off only changes the clock for me, the EPG never matches.
    Have to have clock 1 hour behind the actual time for it to match the EPG.
    Jul 2008
    Yes same here is everyone's the same i.e. the epg hasn't been adjusted with the time change so is 1 hour out. Can anyone help.
    Apr 2017
    Hi yeah i get the same issue.
    I found using the Sat epg works ok, its the XML epg that has the issue.
