Results 1 to 4 of 4
    Apr 2017
    ORZYSZ
    Default Mercedes CLS 3.0cdi
    Colleagues will check whether this is a properly done program or maybe it has original not moved ?????
    Auto reportedly has definitely turned off and blinded egr
    Deleted dpf and flaps from the collector and sure is done power in the car
    Auto at slow speed slightly blue-white copy and when pressed black and turbine as if it had to be reloaded when the pedal pressed to the floor without the computer accelerated to work until 2.980 and falls rapidly to 2,300 and again pumping. Auto accelerates with such jumps and no errors in the compa did not pop up was diagnosed auto com and star diagnosis so I think the problem lies in the program side
    Turbine made a month ago with new collectors and MB flow meters
    CLS V6 320cdi.zip
    immokill's Avatar
    Jun 2009
    UNIVERSE
    if you have star you can reprogram ecu and all will be fine . had same problem w221 cdi.
    Regards
    Poslato sa HUAWEI SCL-L01 uz pomoć Tapatoka
    Here to HELP!
    Apr 2017
    ORZYSZ
    Can be restored to factory settings ???? Do you have any instructions on how to do star diagnosis ???
    immokill's Avatar
    Jun 2009
    UNIVERSE
    just go in ecu and offline programing ,wait 10m wirh charger connected follow instructions
    Here to HELP!
